Is it possible to have multiple custom reports?
Is my only option to export my portfolio to a .cvs file and use a spreadsheet program ?
Thanx.
Multiple Custom Reports ?
Is it possible to have multiple custom reports? Is my only option to export my portfolio to a .cvs file and use a spreadsheet program ? Thanx.
Hi NewCastlePA,
You can have as many custom reports as you want. Each time you go to the top level "Reports" menu and select "Custom" you are creating a new custom report window. You can see all your open windows under the top level "Window" menu, and switch between them. If you want to remember your preferences for different custom reports, memorize them and assign a name to them using "Edit / Memorize Report". Your memorized reports will be listed at the bottom of the "Reports" menu for easy recall.
Who is onlineUsers browsing this forum: No registered users and 2 guests |
