Hi
In custom reports I'm looking for a function that returns the change in a fund/share price, without considering any distributions, between selectable dates. Can you point me in the right direction, thanks.
SS
Share Price percentage gain.
Hi
In custom reports I'm looking for a function that returns the change in a fund/share price, without considering any distributions, between selectable dates. Can you point me in the right direction, thanks. SS
Hi SS,
See the Custom report field: Change in price (between) which will return the change in share price between the starting and ending report dates.
Hi Mark
You have, of course, answered my question perfectly. However, I should have asked: how do I display the percentage change, between dates, in share price in a custom report. Regards SS
Hi SS,
There is no built-in Custom report field to show exactly this. You can get the percentage change in price that includes per-share distribution amounts with the %Gain-F fields. However, if you want the percent change without distributions you would need to write your own equation. You can do this in the Professional and Advisor versions. You would define your own field using the equation: 100.0*(End_NAV-Beg_NAV)/Beg_NAV
Hi Mark
Would you consider adding this function to the next update of FM Regards
Hi SS,
Okay, thanks for the feedback, we can see about adding this field.
Hi divinvest,
How do you want to calculate the "share price between"? Just a simple change?
Hi divinest,
Sorry, it still works as before, where %Gain-F includes distributions/share, and there isn't a dedicated field without these.
Who is onlineUsers browsing this forum: No registered users and 4 guests |
