Distributions
Postby gcgucken » Mon Jul 02, 2012 6:07 pm
In an open lots report does Distributions mean, the sum of all distributed (not reinvested) distributions during date range?
gcgucken
Postby Mark » Tue Jul 03, 2012 10:10 am
Hi gcgucken,
The "Distributions" column includes all distributions paid by the lot on that line. It doesn't matter whether they were distributed or reinvested, they are all included. If the distribution was reinvested that creates a new lot, and it will be shown on a separate line item in this report. The Open Lots report does not have a date range, it is reported as of a particular date. So, any distributions from the date you opened the lot to the ending report date will be included.
Postby gcgucken » Tue Jul 03, 2012 11:03 am
Thank you, I wanted to make sure Distributions had no impact on cost basis. Correct?
GCG
gcgucken
Postby Mark » Tue Jul 03, 2012 12:45 pm
Hi GCG,
Correct, for that lot distributions do not affect its cost basis. If you reinvest those distributions, it will affect the cost basis of the overall investment, but not that one particular lot.
Postby gcgucken » Tue Jul 03, 2012 1:39 pm
And if I input all reinvestments of distributions as such, the cost basis for each lot is accurate?
GCG
gcgucken
Postby Mark » Tue Jul 03, 2012 4:08 pm
Hi GCG,
Yes, if you enter reinvested distribution transactions the cost basis of all those purchased shares is tracked accurately.
Postby gcgucken » Tue Jul 03, 2012 4:53 pm
Thank you,
GCG
gcgucken
