Rebalancing
Postby PWatson » Wed Sep 12, 2012 8:04 pm
Hello folks,
I'm still a new, learning user, but I found a way to rebalance a portfolio and thought I'd share and see if others had a better approach. I have the following portfolio tiers,
...Client Master List
...........Client Master Portfolio
...............Client 529's
...............Client Investments
...................Client Sub-Portfolio A
...................Client Sub-Portfolio B
...................Client Sub-Portfolio C, etc.
I ran rebalance, asset allocation and goal allocation reports for the Client Investments level. ( I use the goal tab to label the large pieces, lg cap, md cp, sm cap, etc., while I break the asset type type into more detailed Morningstar slices. This gives me an overview and a detailed view.)
Once I had the reports, I created another sub-portfolio, at the lowest tier, to manually enter my portfolio changes, labeled them as needed, using the description area to indicate which actual sub-portfolio held that particular investment. I monitored the report to see the effect of the changes as I made them. I did this until I had the balance I was looking for.
After I got what I wanted, I moved the newly created "dummy" sub-portfolio up a level, on the same level as the 529's. There, it no longer combined with the other subs for reporting, and the reports go back to their original state. I can easily move it back in place at any time.
As a newby, I got excited thinking about this tonight. Are others using similar, or better methods?
Phil
PWatson
Postby Mark » Thu Sep 13, 2012 9:20 am
Hi Phil,
Glad you found a solution that works for you. It seems fine to me, but I didn't really follow what criteria you wanted to use in rebalancing your accounts? Are you trying to rebalance to both investment goal and asset type categories at the same time?
Postby PWatson » Thu Sep 13, 2012 2:27 pm
Sorry, that was somewhat irrelevant to the hierarchy post. However, my use of the goal allocation labels could be thought of as "type" and the asset type labels as "sub-type," again allowing me to see an overview allocation, i.e. stocks/bonds/cash. The detailed "sub-type" breaks the pieces up into size/style/type/durations, etc.
I rebalance to the detailed view.
Phil
PWatson
Postby Mark » Thu Sep 13, 2012 2:36 pm
Hi Phil,
I see... Sounds like a fine re-balancing approach to me.
Postby PWatson » Fri Sep 14, 2012 6:05 am
...and for further clarification of my original post, the 529's were part of this clients' financial life and can and should be tracked. However, I do not want to have them included as part of the clients investment portfolio, effecting the allocation. That's why it's up 1 level. I will also plan to keep all other non-investment portfolio assets up 1 level. Reporting from the highest level parent will provide a total net worth. Keeping the investment portfolio 2-3 tiers out lets me review, report and rebalance it exclusive of the other assets.
Phil
PWatson
