Property Fileds: Custom1:, Custom2:, etc
Postby Tintin » Sun Dec 02, 2012 9:07 pm
In the properties, under [Custom], I changed the name of [Custom8] to [Underlying]. In that field I entered the Symbol of the stock for each option that was sold, bought or closed as part of the [Properties]. I also entered the the Symbol in [Underlying] for Stock in it's [Custom].
Now I need to create a report showing all the transactions of both the Stock and all the options that were traded for that stock.
Any help would be welcome. I guess, the last resort would be to dump to an Excel, and do the work there.
I need to clean up my basis due to some assigment that were not cleaned up from option to stock.
- if only there was a way to filter on these [CustomX] fields. If Symbol=STOCKNAME
I was thinking of a report for all entries in the portfolio with [Custom8:]=STOCKNAME, or in my case, [Underlying] = STOCKNAME
I guess I could go back and enter the STOCKNAME in the Memofield for ALL transactions, but that is a BIG job.....
Thank you in advance. -= Tintin =-
Tintin
Postby Tintin » Sun Dec 02, 2012 9:47 pm
Ah! Nothing like answering your own question.
I used a feature I never tried before! I exported the whole portfolio [File][Export][Transactions][Generic] using the Export Format: SYMB,MM/DD/YY,TRAN,IAMETH,BNUM,ANUM,CNUM,MEMO,CIP08,CIP09
as a cvs file,
Then into Excel. Cleaned up the non needed trades using Excel's filter, and 'voila'.
Ideally I would also need the value of the trades (<Shares><Price><Value><Commission>), but I can do that in Excel, or dig deeper into the Export Format syntax,
You truly have a feature rich program to meet any unique idiosyncrasies from your user base.
THANK YOU!, Cheers -= Tintin =-
For the benefit of other readers....
Tintin
