OPP basis per share without dividends
Postby Ivan » Thu Feb 14, 2013 11:27 am
I have the personal edition. Is there a way to get the current OOP basis per share NOT including the contribution of dividends? I use this figure to help determine stops.
Ivan
Ivan
Postby Mark » Thu Feb 14, 2013 11:33 am
Hi Ivan,
If you don't want to include any distributions in the basis, use the tax basis fields. If you want to include all distribution types except dividends, there is no built-in field for this. In the higher level versions (Professional/Advisor) you could write an equation to calculate the OOP basis, and add back in the dividend distributions. Otherwise you could just include both on a report in the Personal version.
Postby Ivan » Thu Feb 14, 2013 11:42 am
Thanks Mark. The tax basis per share is exactly what I needed.
Ivan
Ivan
Postby Ivan » Sat Jul 06, 2013 3:56 pm
Hi again Mark,
Tax basis per share Assigned has appeared to work properly up to now, ignoring dividends in the calculation. But I just ran into one investment where the latest dividend does change that cost basis value. I can't see where that investment or dividend is different. Any suggestions?
Ivan
Ivan
Postby Mark » Sat Jul 06, 2013 4:53 pm
Hi Ivan,
Is it really a "dividend" type of distribution? Was it reinvested? If a dividend is reinvested, that will affect your cost basis. If it wasn't reinvested, a dividend should not affect your tax cost basis. If you record it as an "account fee" or "return of capital" type of distribution, those can affect your cost basis.
