Security Cross-Reference Report?
Postby stevetone » Tue May 20, 2008 8:48 am
Howdy:
I am running a small RIA firm and my regulatory agency requires a report that lists, by security: client name, account number, and shares owned. I have tried to create a suitable report, but have not figured it out (yet).
I'm probably missing something here...any suggestions? Is it possible?
Thanks for your help!
Steve
stevetone
Postby Mark » Tue May 20, 2008 10:21 am
Hi Steve,
There are a couple of ways you can do this, depending on how you want it formatted.
1) Set up your client's sub-portfolios with their name and account number. When you report on this sub-portfolio, this information will be in the report header. You can then do any type of report, like the Portfolio Value report, which lists shares of each item. You can optionally sub-total by any lower level sub-portfolios, like if they have accounts beneath.
Example sub-portfolio hierarchy:
Code: Select all
My RIA Firm
  Client XYZ
     Acct 12345
     Acct 6789
  Client ABC
When you create a report, report on "Client XYZ", and turn on sub-totals by sub-portfolio. List by investment.
2) If you wanted to see the account number on each line, you can do this by creating a custom report, and adding this field to the report.
Postby stevetone » Wed May 21, 2008 8:40 am
Mark:
I have the portfolios structured as in your example but I don't think that the suggested report will do what I need. I'm picturing a report that is something like:
Code: Select all
Security A
   Client XYZ     Acct12345    100 shares
   Client ABC     Acct67890    150 shares
Security B
   Client XYZ     Acct12345    300 shares
   Client QRS     Acct45678    100 shares
This cross-reference would be by security across all sub-portfolios.
Can do?
Steve
stevetone
Postby Mark » Wed May 21, 2008 8:56 am
Hi Steve,
Try a report with these settings:
Sub-Portfolio: "My RIA Firm" (or your topmost sub-portfolio)
Type: Custom
Custom fields included: "Portfolio Parent", "Account", "Shares (ending)"
Sub-total: On, by Symbol
List By: Investment
Postby stevetone » Thu May 22, 2008 7:58 am
Mark wrote:Hi Steve,
Type: Custom
List By: Investment
Mark:
Thanks for the fast and friendly (and patient) help. That report looks like it will do what I want. I just need to rename my sub-portfolios a little differently to make sure that the needed information is all on the report. Will also need to add Account #s to all the investment properties (only had it enter on the sub-portfolio's properties, which kind of makes sense, no?)...unless I can get the Parent Portfolio's Account # on the report detail???
Keep up the great work!
Steve
stevetone
Postby Mark » Thu May 22, 2008 8:15 am
stevetone wrote:...unless I can get the Parent Portfolio's Account # on the report detail???Steve
As I was writing my last reply, I had the same thought. I've documented that we should add a new custom field "Sub-Portfolio Account #", that works in the manner you're looking for.
Another possible work-around for now is to just include the account number in the sub-portfolio name, and don't include the "Account" field in your report. When you're renaming your sub-portfolios, you could do something like this: "Client XYZ (Account 12345)". It might be easier the recording account numbers for all the investments.
