sum of two colums
Postby alpappy » Sat Sep 21, 2013 9:50 pm
HI is it possible to create a user defined column which is the sum of two parameters ie gross interest minus tax equals net income( new column)'thanks
alan
alpappy
Postby Mark » Sun Sep 22, 2013 10:23 am
Hi alan,
Yes, in the "Custom" report, when you are using the Professional or Advisor versions you can define your own fields. You can create an unlimited number of these, and you write an equation to define them. You can make use of the built-in fields as part of your equation, and perform math on them, so you can make a new user-defined field that is the difference of two built-in fields. From within the Custom Settings... dialog, press the "Define Fields..." button in the lower-left corner.
