Custom Report for % Above 10Month MA?
Postby Bosox13 » Fri Sep 27, 2013 7:54 am
I would like to create an equation that will tell the % Above/Below 10 month SMA instead of Weekly....Is there anyway to do this?
Thanks for your help
Bosox13
Postby Mark » Fri Sep 27, 2013 10:52 am
Hi Bosox13,
All moving averages are calculated on a daily resolution, so a 10 month moving average is pretty close to a 40 week moving average. So, you can define a field like this:
100 * (End_NAV - MA40W) / MA40W
or, maybe 10 months is closer to 45 weeks, in which case you can use:
100 * (End_NAV - MA45W) / MA45W
Postby Bosox13 » Sun Sep 29, 2013 12:54 pm
thanks mark...I initally did that, but i just didn't want to include all of the data points of the weekly MA (ie 4 points of data).....i just wanted to find a way to get the 1 data point for the end of the month....thanks for your help - i appreciate it
Bosox13
