make columns fit and save
Postby alpappy » Sun Oct 27, 2013 12:29 pm
HI How can set the columns in reports to fit the date and save the settings or can you add an option to allow the cloumn to expand/contract to fit the data
thanks
alan
alpappy
Postby Mark » Mon Oct 28, 2013 9:41 am
Hi alan,
Are you talking about reports, or the Portfolio Editor? Reports do auto-size their columns to fit the content by default. Maybe you turned it off? If you're in a report, select "Window / Auto-Size Columns" which should size all the columns to display your content, and no extra white space.
A related option is: "Options / Report Preferences... / General / Auto-Size Columns When Report Data Changes". If this is off, then your column widths just stay where you last set them manually.
