bond report
Postby alpappy » Fri Nov 01, 2013 11:21 am
Hi Is it possible to add a column in the bond report for the actual value of the holding as at present it shows just face value thanks alan
alpappy
Postby Mark » Fri Nov 01, 2013 11:39 am
Hi alpappy,
Unfortunately, this is not one of the available fields in the "Bond Summary" report currently. We will consider adding this. You can add the "Price" field. You can see all the available fields for this report under "Options / Report Preferences... / Bond Summary". As I'm sure you know, you can get the market value in several of the other reports, such as Portfolio Value.
