Batch Reporting - Floating Date
Postby bkennedy » Fri Nov 08, 2013 2:07 pm
Is there a way to select a Date Setting/period on a report as "Earliest transaction to date" or another floating date and it apply correctly to all reports in a batch. Currently, the batch process does not recognize that a selected client has a unique "Earliest Transaction To Date". Thanks
bkennedy
Postby Mark » Fri Nov 08, 2013 2:20 pm
Hi bkennedy,
Sorry, this isn't an option for the batch printing. The only thing that changes between printing is the report is calculated for each client's sub-portfolio, but all the other settings (including date range) remain the same. This typically works well for doing quarterly or yearly reports, but I can see why you might want an option to vary the start date back to inception. We can consider adding this option.
