Is there a way to do this? If not, I suggest you add it. I often insert other material within a report (not just at the front) and this blows the page numbering so I can't use the batch feature.
Elliot Lipson
Turn off page numbering in batch reporting
Hi Elliot,
You can remove page numbers when printing. Go to "Options / Report Headers..." and remove: [[ -IF]][[PRINTPAGE#]] from the "Sub-Title" section. You would need to do this for each report type you'll be using.
Who is onlineUsers browsing this forum: No registered users and 16 guests |
