prints from 2014 version
Postby gbfabiani » Mon May 12, 2014 3:44 am
Hi Mark, I occasionally print reports in pdf form .
When I use Parallels on my Macbook I define as a printer "pdf on mac" .
On the new version if a report is wider than the page can accept , the system offers the option to adapt automatically the print ( very useful!) . However in these situations the pdf file become very large ( one page 220MB versus a page with no "compression" 67KB) .
I tryied a different report on windows , uising both 2013 and 2014 versions, 11 pages print and a driver to exit with PDF : situation is better, but still I have >1MB per page .
I imagine because of the mac/parallel issue it is not something important, nevertheless if you could give a look on the way the page is compressed.....
thanks
giovanni
gbfabiani
Postby Mark » Mon May 12, 2014 8:52 am
Hi giovanni,
This could be expected, although I'm surprised somewhat by the size of the file you're reporting. When you use the "scaling" feature FM prints in a slightly different manner, that could cause PDF printers to create larger files, as they are image based instead of vector based. I did a test here, and got a 32KB non-scaled PDF, and a 1.1MB scaled PDF. Your 220MB sounds quite large... My test was done with PrimoPDF.
If the size of the file is an issue, you might try either a different PDF printer/driver, or turn off the "scaling" feature. Of course if you turn off the scaling feature you would need to make sure you use a small enough font for the report to fit on a page.
