Highlighting Rows in Reports
Postby Emvin » Wed Aug 27, 2014 1:32 pm
Is there a way of selecting and highlighting individual row/s in reports?
Emvin
Emvin
Postby Mark » Wed Aug 27, 2014 1:55 pm
Hi Emvin,
No, you can't select rows in reports. You can however move your mouse over them, and perform an operation on a specific row by right mouse clicking it.
If you're trying to grab just a few rows for some reason you can export the report to a CSV file, and then work with the data from that file. See "File / Export to CSV..." from within any report window.
Postby Emvin » Wed Aug 27, 2014 3:13 pm
That's what I suspected, Mark. Thanks for confirming this. It would be a useful addition to a future version, though.
Meantime, I'll export the file as you suggest. I appreciate your prompt reply.
Emvin
Emvin
Postby Mark » Wed Aug 27, 2014 3:41 pm
Hi Emvin,
Okay, thanks for the feedback/idea.
