Correlation Matrix
Postby paulk » Tue Oct 14, 2014 11:22 am
Any way to shrink the headers on just this report to get my columns to fit on a single page? As it stands now some of my asset classes have relatively lengthy names and the column headings of this report will just accommodate the first few letters of each one. If I widen the column then I can just fit a few columns on the page. I'd use the report a lot more often if I could get it aesthetically pleasing.
paulk
Postby Mark » Tue Oct 14, 2014 12:02 pm
Hi paulk,
Did you try the "Compact Format" option on the Report Settings? You can also customize each individual column to whatever width you want. Is there some other way you would like to see this report displayed?
Postby paulk » Tue Oct 14, 2014 3:32 pm
I did try the compact format checkbox and I did widen the columns. I guess what I would like would be the ability to shrink the column heading fonts and wrap the text for the column headings (onto tow or three lines) in order to keep the column width just as wide as the numbers listed below it but retaining the ability to read the entire column heading. Don't know if thats a possibilty.
paulk
Postby Mark » Tue Oct 14, 2014 3:47 pm
Hi paulk,
I see... It isn't a possibility today, but maybe in the future. Maybe it would make sense for an option to draw those column labels vertically, as opposed to the normal horizontal text label. That would allow you to read the whole label, and keep the width just as wide as the numbers in the table. It would increase the height of the report, but there should normally be space in that direction.
Postby paulk » Tue Oct 14, 2014 5:03 pm
Thanks Mark
paulk
Postby paulk » Tue Oct 13, 2015 4:23 pm
Bumping this thread to see if this modification has been added to the 2016 version of Fund Manager.
paulk
Postby Mark » Tue Oct 13, 2015 5:17 pm
Hi paulk,
Sorry, no, we didn't make any improvements related to this...
