current drawdown function
Postby frankpazulski » Fri Oct 17, 2014 5:59 am
Hey Mark,
Can you give me a custom function for a report for highest nav minus end nav divided by highest nav times 100 if end nav is less than or equal to highest nav with a red negative number.
Thanks for all your help.
Frank
frankpazulski
Postby Mark » Fri Oct 17, 2014 9:10 am
Hi Frank,
I'm not sure I followed all the details of your request/conditions, but I think you're asking for something like this:
100*(Highest_NAV-End_NAV)/Highest_NAV
BTW, the End_NAV will always be less than or equal to Highest_NAV.
Postby frankpazulski » Fri Oct 17, 2014 9:20 am
yes I think that what I want, how much drawdown from the ytd highest closing nav in percent terms if present nav is less than highest closing nav, can it be made to have a red font and a negative number, and what is the function formula.
Frank
frankpazulski
Postby Mark » Fri Oct 17, 2014 10:14 am
Hi Frank,
If you want it to be negative, write the equation accordingly. Negative numbers will automatically be displayed in red. For example, to make this a negative number, it would be:
100*(End_NAV-Highest_NAV)/Highest_NAV
Since, Highest_NAV is always greater than or equal to End_NAV, this results in 0 or a negative number.
Postby frankpazulski » Fri Oct 17, 2014 10:20 am
Awesome Mark, thanks for your help. Any way to add this to portfolio editor as well as current yield from custom report.
Frank
frankpazulski
Postby Mark » Fri Oct 17, 2014 10:44 am
Hi Frank,
Sorry, no. User-defined fields are only available in the Custom report.
