Rebalance report
Postby unter » Tue Dec 16, 2014 8:10 am
In one of my portfolios I have asset types set up but when I print a rebalance report everything comes up N/A. When I print an asset allocation report it shows the allocations. I have the rebalance allocation targets and they work on other portfolios. Any ideas?
unter
Postby Mark » Tue Dec 16, 2014 10:35 am
Hi unter,
I would double check your assigned allocation target. Open up "Edit / Report Settings..." in that report, and choose "Allocation Targets: <Edit Allocation Targets...>", and edit the one you're using, and make sure you select that same one, and it isn't a different/similar name. You should see the name of the allocation target in the report header as well.
