Sorting Report Columns
Postby GregSchr » Wed Aug 06, 2008 5:32 pm
Is there a way to choose which column is used for sorting in a custom report?
GregSchr
Postby Mark » Wed Aug 06, 2008 5:52 pm
Hi GregSchr,
Yes. While viewing a report you can sort by any displayed column by using the top level "Sort" menu. Just pick which column you want to sort by. You can also choose to do an "Inverse Sort" under this menu.
Postby GregSchr » Fri Aug 15, 2008 1:38 pm
Thanks... It was so obvious I missed it.
GregSchr
