Monthly Performance OOP % Gain
Postby marathon » Sun May 10, 2015 12:43 am
Hi
Anyone can help?
Can I check what is the math behind the calculation because I cannot tally the monthly with the totals.
Have tried the obvious methods
1. adding up monthly totals (which is the "naive" way)
2. Using geometric i.e. (1 + Jan %) x (1 + Feb%) x ... (1+ Dec%) -1
Am expecting to have the exact same answer when comparing the total performance for the year with the monthly
marathon
Postby Mark » Sun May 10, 2015 11:55 am
Hi marathon,
This figure is not time weighted. It is a simple summation/division for whatever object/time period you choose. It is re-calculated for each separate object/time period in your report. The equation is shown here:
https://www.fundmanagersoftware.com/hel ... n_oop.html
