Percentage Change in share price from Highest.
Postby Sterling Silver » Tue Oct 06, 2015 9:56 am
Hi, Is there a field to show, in a custom report, the % change of a share price from its highest or lowest value during a specified period.
Sterling Silver
Postby Mark » Tue Oct 06, 2015 10:55 am
Hi Sterling Silver,
There isn't a built-in field for exactly this. Something similar is "Maximum drawdown (between)". If you're using Professional or Advisor, you can write your own equation to get this:
100*(Highest_NAV-End_NAV)/End_NAV
or
100*(End_NAV-Lowest_NAV)/End_NAV
Postby Sterling Silver » Tue Oct 06, 2015 11:15 am
Thanks Mark, Unfortunately I use the Personal version. :(
Sterling Silver
