decimals in Performance report 2016
Postby gbfabiani » Thu Oct 08, 2015 12:42 pm
The 2 colums right on the standard Performance Report ( I use %gain and %yeld) show 1 decimal point : I'm not 100% sure, but I feel before the new 2016 release the had 2 . I didn't find in the option if and where we can change the decimals after the comma . Considering the type of info , particularly on short periods of time, I feel 2 decimals are required
gbfabiani
Postby Mark » Thu Oct 08, 2015 6:44 pm
Hi gbfabiani,
Yes, this is a new option. It defaults to 1 digit for percentages, but you can change it at:
Options / General Preferences... / Display / Percent Digits
Postby gbfabiani » Fri Oct 09, 2015 6:10 am
Cool ! I did look to Option/ Report preferences , that's why ..... Thanks Giovanni
gbfabiani
