Investment Order
Postby jb3 » Tue Jan 12, 2016 1:15 pm
Hi Mark
Is there a way to auto-magically re-arrange the order of investments in a report according to the investment type, rather than manually dragging each into its proper place?
John
jb3
Postby Mark » Tue Jan 12, 2016 1:32 pm
Hi John,
There are several options here:
1) Sub-total your report by Investment Type. This will put all the investments into each sub-total section. You control the order of the investment type sub-totals with "Options / Investment Type...".
2) Sort your report by Investment Stack (which is the default), and order your investments in the stack by investment type by using "Investments / Sort By / Investment Type".
3) If you're using a Custom report, you can add "Investment Type" to the report, and then sort by that field using the top level "Sort" menu.
Postby jb3 » Tue Jan 12, 2016 2:09 pm
Thank you!
jb3
