by mecrews » Fri Jan 29, 2016 3:43 pm
Hello,
*Edit: I put this in this forum because the issue shows up on my Executive Summary report
I moved shares of Kinder Morgan (KMI) from an IRA account to a non-IRA account.
However -- I kept getting the OOP Cost Basis as the withdrawal???
I expect/want the withdrawal amount to be the market value as this is what will be reported for income.
As always -- I'm sure I missed the obvious (hopefully)!
Matthew
mecrews
by Mark » Fri Jan 29, 2016 4:02 pm
Hi Matthew,
Did you transfer the shares by using "Transfer" transactions? If so, you can control how OOP Calculations are performed for transferred shares under "Options / General Preferences... / Other / Transfer Transaction OOP Calculations Use:". I believe you want this set to "Market Value" instead of "Original OOP".
by mecrews » Sat Jan 30, 2016 10:31 am
I'm sure that will take care of it -- I knew there had to be a configuration choice -- I just didn't know where to look. If there is reference to this in the documentation -- I couldn't find it. I believe FM does much more than would appear on first glance!
Thanks again as always,
Matthew
mecrews
by Mark » Sat Jan 30, 2016 10:39 am
Hi Matthew, This is described in the online help for the dialog where you can adjust it: https://www.fundmanagersoftware.com/hel ... other.htmlbut it isn't linked from the online help for the Executive Summary report. I can definitely understand it being hard to find if you're not aware of it... Maybe a link in that report's help page would help.
by mecrews » Mon Feb 01, 2016 12:19 pm
Thanks for the link and the help. I'm not sure I would have ever found that information based on the link progression listed below -- fwiw.
Online Help -> About Investments -> Investment Properties Dialog -> General Data Options -> See Also: General Preferences -- Other Dialog
Matthew
mecrews
by Mark » Mon Feb 01, 2016 12:23 pm
Hi Matthew,
We have updated the online help to better link to this topic for future releases. It will be discussed/linked from the "Out Of Pocket Definition" page as well.
by mecrews » Mon Feb 01, 2016 1:58 pm
Thanks! Hopefully that will be helpful to others as well.
Matthew
mecrews
