help with total
Postby alpappy » Sat Feb 06, 2016 7:38 pm
HI All I need is a report that shows the difference between the starting date of the report and closing date of the report in home currency Which value change do I use None seem to do this and often the total that should be negative ..red is black positive thanks
alan
alpappy
Postby Mark » Sun Feb 07, 2016 11:43 am
Hi alan,
In a Custom report, you can use the field:
Change in value (between)
Also, if you are using non-default currencies and want to see it in your default currency, make sure "View / Exchange Rate Adjusted" is turned on.
