New column with macro
Postby alpappy » Fri Feb 12, 2016 11:18 am
HI Is it possible t create in custom reports a new column and us a formula or macro
Say for example when using accrual...Taxable income
macro or formula
Accrued income start minus coupon paid plus accrued income end
alan
alpappy
Postby Mark » Fri Feb 12, 2016 5:27 pm
Hi alan,
Yes, if you're using the Professional or Advisor versions you can write your own equations and define your own fields. Create a Custom report, and choose the "Custom Settings..." button and then press "Define Fields...". Press the "Help" button in there for instructions/examples.
