Backup of memorized Custom Report settings
Postby jelode » Tue Mar 29, 2016 11:39 am
Hello,
Is it possible to make backups og memorized custom report settings?
Regards,
JELode
jelode
Postby Mark » Tue Mar 29, 2016 3:42 pm
Hi JELode,
Yes, a regular backup using "File / Backup..." will include these settings. The memorized reports are stored in the registry, and all of this is backed up when you do a backup. You will have a single *.FMB backup file that contains all your data files and registry preferences.
Postby jelode » Wed Mar 30, 2016 11:28 am
Thank you Mark.
So if I for any reason need to re-install Fund Manager I only have to restore the backup file and then I will regain the memorized reports?
Regards,
JELode
jelode
Postby Mark » Wed Mar 30, 2016 11:33 am
Hi JELode,
Yes, that is correct.
