Custom Report : Highest High Date
Postby SHAREVJ » Fri Jul 08, 2016 12:50 am
Is there any way to get the dates of highest high, lowest low in Custom Report. At present custom fields support only Highest High value or Low value, in Date Fields the date of Highest high or Lowest Low is not there. Highest high date can be provided for dates between the report date.
Please suggest a method to get it.
SHAREVJ
Postby Mark » Fri Jul 08, 2016 9:09 am
Hi SHAREVJ,
Sorry, no, this isn't available in a report field currently. One way you could get this is from a graph's data. You could either visually get it from the graph using your cursor, or you could export the graph's data points to a CSV file using "File / Export / Other / Graph Data Points...". Open up the data in Excel and sort by the plotted value data column.
Postby SHAREVJ » Sat Jul 09, 2016 1:20 am
Thank you for the suggestion. Will Try. However please consider this in future releases.
SHAREVJ
