Pie Chart Asset Type Labels
Postby Cole » Sun Jul 31, 2016 8:16 pm
When creating a pie chart graph, the percentage of asset is shown that is color coordinated with the graph, but the asset type label is not showing by the percentage. How do I turn that option back on? Could it also be that I changed the graph font color to black by mistake and since the report background is black that asset type labels blend in? Either way, some suggestions as how to fix this are much appreciated.
Thank you,
Cole
Cole
Postby Mark » Mon Aug 01, 2016 7:26 am
Hi Cole,
That text is controlled with the color called "Yield Text" under "Options / Colors...".
