Reports/Portfolio Value
Postby reddragon » Mon Sep 12, 2016 11:44 am
I am having a problem reconciling accounts getting the proper Portfolio Value. All the numbers and Data are correct but the portfolio Value is wrong. I never had this problem before. I just upgraded the software but I do not thing that is the problem. Do you have any suggestions?
reddragon
Postby Mark » Mon Sep 12, 2016 11:51 am
Hi reddragon,
If the portfolio value is wrong, one or more of the investments in the portfolio have the wrong value. Take a look at the investment values. If they are all correct, then the total portfolio value is correct. Also, make sure you don't have any hidden investments with a value. Turn on "View / Hidden Investments/Portfolios" to see everything. You might also want to watch this tutorial on reconciling:
https://youtu.be/eewZ250W_FY
Postby reddragon » Mon Sep 12, 2016 3:06 pm
Got it Thanks. Also every time I download Historical Pricing prices are wrong compared to my statement. Example ETF ( SPY) statement says 209.4750 Download 209.4899 or something like that. Ant suggestions?
reddragon
Postby Mark » Mon Sep 12, 2016 3:33 pm
Check that the symbol you have recorded is correct. If so, go to the quote server you're using, and see what they're reporting for a price for that symbol. It should be the same price retrieved by Fund Manager.
Postby reddragon » Tue Sep 20, 2016 10:33 am
I,m having a hard time with this. What is on my Statement is for example is quote for SPY as of 04/29/2016 is 206.3308. What is being pulled in from Yahoo is 206.330 a difference of 8 cents.
This is what I,m off by 8 cents. Is there some adjustment I can make?
reddragon
Postby Mark » Tue Sep 20, 2016 10:49 am
Hi reddragon,
Yahoo (Historical) is downloading a price of $206.330002 for SPY on 4/29/16. You may only see $206.33 unless you edit the price, or turn up the price digits for display under "Options / General Preferences... / Display". If you want to edit this, and change it to $206.3308 you can do this by going into the Data Register. Set the data type to "Prices", select this price, and click "Edit". You can see the Data Register tutorial here:
https://www.fundmanagersoftware.com/tut ... video.html
