Ability to Group Memorized Reports
Postby paulk » Wed Sep 28, 2016 11:43 am
Hi Mark
Is there any way to do something like set up a group of memorized reports that need to be run regularly? I have a group of 6 or 7 reports I send out on a quarterly basis and the ability to keep them in some sort of sub folder in the memorized transaction list would be helpful.
paulk
Postby Mark » Wed Sep 28, 2016 12:33 pm
Hi paulk,
Sorry, no, you can't create a group of memorized reports. You can name them anything you want, that might help you to know which 6-7 reports you want to run regularly.
Postby paulk » Wed Sep 28, 2016 1:30 pm
Thanks Mark
If you could add that to the list of suggested improvements that would be great. I don't know if it is feasible (programming wise) but it would be helpful.
paulk
Postby Mark » Wed Sep 28, 2016 3:26 pm
Hi paulk,
Okay, thanks for the feedback/idea.
