Custom tab of Investment Property
Postby flight » Sat Oct 22, 2016 6:55 pm
Mark, what can this be used for?
For example, I have a custom tag that I want to apply to my positions that is not asset class or sector based. And then, ideally I like to use that tag to run different reports. Is that possible?
Say for example, I want to tag my portfolio around categories such as: cyclical, interest rate sensitive, etc.
thanks
flight
Postby Mark » Sun Oct 23, 2016 9:54 am
Hi flight,
You can use these to keep track of any other related information on your investments. They aren't used like categories, where you can filter, sub-total etc by category. For example, you could track the expense ratio of each of your investments, or P/E ratio, or any other statistic/information you want to know. You can control how these get combined when calculating for a portfolio, like whether to sum, average, weighted average, min, max, etc... You can use them for tracking not only numbers, but text strings or a date. For an example usage, see this FAQ:
https://www.fundmanagersoftware.com/expense_ratio.php
Postby flight » Sun Oct 23, 2016 3:27 pm
How do you control how the statistics get combined when calculating for a portfolio? or, where do you select this?
flight
Postby Mark » Sun Oct 23, 2016 3:46 pm
Hi flight,
In the dialog where you define the custom investment properties, which is "Options / Custom Investment Properties...". See the "Combination Method" drop-downs for each property.
