Port. Value report not including investment
Postby jfscullion » Tue Apr 11, 2017 3:58 pm
Attempt to add investment to portfolio, says investment already in portfolio. But Portfolio Value report will not list the investment. Why?
jfscullion
Postby Mark » Tue Apr 11, 2017 4:03 pm
Hi jfscullion,
1) Are you running the report on a sub-portfolio that contains this investment?
2) Is the investment hidden, while you have "View / Hidden Investments/Portfolios" turned off?
Postby jfscullion » Wed Apr 12, 2017 7:43 am
Thanks, Mark. I turned on View, Hidden, and it now shows up. But, when I look at "Investment properties, Other" it is not marked as "hidden".
jfscullion
Postby Mark » Wed Apr 12, 2017 7:47 am
Hi jfscullion,
Okay, then it must not be displayed in your report because of the option:
Options / Report Preferences... / General / Do Not Display Investments With Zero Share Balance
This means that investment has 0 shares owned on your report date, so it is being automatically not displayed. You can change that option if you want, or you can view that investment in another window, like the Portfolio Editor.
Postby jfscullion » Wed Apr 12, 2017 8:02 am
Don't know what I did but it shows up correctly in the report now.
Thanks for your help.
jfscullion
