Default Cash Account Balance
Postby adrianrees » Fri Jun 30, 2017 6:10 pm
Is it possible to generate a report that shows daily closing balances for the default cash account?
adrianrees
Postby Mark » Fri Jun 30, 2017 6:40 pm
Hi adrianrees,
Yes, create an "Investment Transactions" report, and un-check "All in sub-portfolio", so you can select just your cash account. Make sure you have the "Share Balance" and/or "Balance" fields selected for this report in the "Preferences...". You will get the balance on every day that there is a transaction. The balance does not change between transaction dates.
