Dates not displayed properly in Capital Gains Report
Postby divinest » Tue Sep 12, 2017 4:22 pm
Any reason why the dates fields are all showing ascii chars and position names (as attached in the images), i reviewed the data register for the position, the values are fine there. I am using Personal Edition 2016
Screen shot with dates not showing correctly
2017-09-12 19_18_45-Clipboard.png (27.65 KiB) Viewed 4998 times
divinest
Postby divinest » Tue Sep 12, 2017 5:15 pm
Changing the data format from windows to predefined settings in the general pref fixed the issue, thanks!
divinest
Postby Mark » Tue Sep 12, 2017 6:01 pm
Hi divinest,
I'm wondering why the "<Windows Format>" date format didn't work for you? If you set it to "<Windows Format>", how does the "Example:" display? Are you using a non-English version of Windows?
Postby divinest » Wed Sep 13, 2017 3:31 am
Hi Mark, I am using Windows 10 Pro - (Locale set to US English), the sample shows the same behavior as well Thanks!
divinest
Postby Mark » Wed Sep 13, 2017 7:40 am
Hi divinest,
Thanks for the info. If you go into Window's Control Panel and look under Regional settings what do you have for the date format options? Specifically, what is your "short date" format, and language format?
Postby divinest » Wed Sep 13, 2017 1:47 pm
Attached the current windows settings.
Regional settings
2017-09-13 16_46_05-Clipboard.png (19.01 KiB) Viewed 4978 times
divinest
Postby Mark » Wed Sep 13, 2017 6:32 pm
Thanks for the info. This is an odd one. I haven't been able to reproduce this here. If you'd like to try and get this working for you, please send us an email. We may need to go back/forth a few times with a debug version to help us figure out what is going wrong.
Postby divinest » Thu Sep 14, 2017 3:10 am
Thanks Let me know the debug option, i can email the logs etc
divinest
Postby Mark » Thu Sep 14, 2017 11:27 am
Hi divinest,
I just sent you an email with a debug version and instructions. Can you please check that, and let me know the results?
Postby Mark » Tue Sep 19, 2017 11:04 am
Hi divinest,
We just released Beta 3, which should fix this issue. Please let me know if it does not.
Postby divinest » Tue Sep 19, 2017 11:33 am
HI Mark, I will test the same and let you know. Thanks much,
divinest
Postby divinest » Tue Sep 19, 2017 6:01 pm
Hi Mark, I was able to download Beta3 and test, the dates are showing up correctly with the settings of windows format. Any estimate on when the final version is planned on being released ? Thanks much!
divinest
Postby Mark » Tue Sep 19, 2017 6:55 pm
Hi divinest,
Great, thanks for your help on this. The official release date hasn't been set, but probably 2-4 weeks.
