Custom Report Auto size header formatting
Postby divinest » Sat Sep 23, 2017 6:30 pm
Hi Mark, If you see the attached image, on the custom reports, every time have to expand the header to display the full date format, is there a way to change that or make it automatically format to include the complete date field ? Thanks much!
Custom Report auto size format header
divinest
Postby Mark » Mon Sep 25, 2017 11:33 am
Hi divinvest,
If you turn on the option "Order Columns by Date" in the Report Settings dialog, the automatically sized column widths will factor in the date display. If you have that option off, then the date is spread across all fields. In this case, if there are multiple fields, there is usually enough room. In your case you only have 1 field, so there isn't, but if you turn on that option, you'll get the result you're wanting I believe.
