Days Owned in Years
Postby divinest » Tue Sep 26, 2017 4:36 am
Is there an option to include the days owned in custom report, also follow up to that if that is possible, can a user defined field added to display as years or months? Or in the Odd lots reports to display the days owned as years. Thanks much!
divinest
Postby Mark » Tue Sep 26, 2017 10:14 am
Hi divinest,
There is no built in field for days owned in the Custom report, but you can define a field to calculate this. You would use equations like:
Days owned:
ENDDAYS()-Acquired_start_end
Years owned:
(ENDDAYS()-Acquired_start_end)/365.25
