Fund Manager Pro 2018 will not print reports correctly to the registered Adobe PDF printer (Adobe Acrobat Pro) on Win 10 Edu 64 bit. If "resize to 1 page" is off you get a preview which is, of course, far wider than the page. If it is on, you encounter a very outdated error message shown in the attached file. Strangely, you do get an apparently correct preview from the inferior "Microsoft print to pdf" driver. The "install pdf printer" button on the Fund Manager print dialog forces the user to the web page of a 3rd party driver (http://www.primopdf.com/). But that should be unnecessary when an authentic Adobe driver is present and registered. Under certain circumstances, Fund Manager also claims that it does not have enough memory for the print job which is nonsense since the machine is running 24G of RAM. And yes, every other piece of software prints just fine to the Adobe printer. Fund Manager, incidentally, will show a perfectly acceptable preview through the Adobe Postscript driver. Even more curiously, although the quality is poor, a graph window prints to the Adobe printer as well.
A little further exploration yields the following:
1. although it is very slow, a Portfolio Value report will print correctly to the Adobe driver.
2. the report that repeatedly fails is the Transaction Report
The problem seems to be related to the number and width of the columns. If I drop one and slightly resize others to be a bit narrower, it does try to print to the Adobe driver. It still fails though with an "insufficient memory" message. Once you get that error, fundamentally a hard "end task" shutdown is required.
Obviously, there are workarounds, but it is a shame that in an otherwise feature-rich tool the printing interface would be inadequate.
ay
