by flight » Thu Nov 23, 2017 8:02 pm
Just a quick question or two on TWR log files:
1) when I open the log file, it appears to bring in different dates versus the dates ran on the TWR report?
2) when I open the log file, it appears to show ever position throughout history of the account. Is there anyway just to see the relevant positions?
thanks
flight
by flight » Sat Dec 02, 2017 10:54 am
Hi Mark - just wanted to bump this up, and to hopefully get your thoughts and advice. thanks
flight
by Mark » Sat Dec 02, 2017 11:19 am
Hi flight,
Sorry I missed your initial post.
1) This log is cumulative, so it keeps growing/appending. For the latest calculations, look towards the bottom of the log file.
2) It shows all TWR calculations, anywhere in the program. You can clear it out, and then make some change to your report in question, so only that report is re-calculated, and you'll see the data from just that one report. Make sure you don't have a bunch of report windows open, all calculating TWR, as that will make it difficult to find the calculations in question.
by flight » Sat Dec 09, 2017 6:13 am
By clear it out, do you mean delete it?
flight
by Mark » Sat Dec 09, 2017 9:37 am
Hi flight,
Yes, you could either delete the file, or while it is open, select all the text, delete the text, and re-save the file, as an empty file. Either way would work to clear the log file.
by flight » Sat Dec 16, 2017 9:25 pm
Regarding question # 2 (when I open the log file, it appears to show ever position throughout history of the account. Is there anyway just to see the relevant positions?), every cash flow or calculation period seems to have every investment ever owned.
it makes it difficult to reconcile and review?
for instance, I'm looking at performance calculations for 2010, and in the particular period, I see holdings I bought in 2016 (and every other year), yet they are irrelevant to my 2009 performance:
here's an example: the 2009 cash flow period shows a call option I sold in Dec of 2017. It's strange and a lot of "noise" to scroll through.
Cash Flow Period: 7/29/2009 - 9/10/2009 BMVi: 76409.680000 EMVi: 85390.105000 Yieldi: 11.75 Yield: 72.31 REV 15DEC17 25.0 C Market Value: 0.00
flight
by flight » Sat Dec 16, 2017 9:30 pm
Is there anyway just to see this information:
Cash Flow Period: 2/25/2009 - 5/ 8/2009 BMVi: 42452.180000 EMVi: 62445.750000 Yieldi: 47.10 Yield: 38.79
flight
by Mark » Sun Dec 17, 2017 8:40 am
Hi flight,
No, there are no options for controlling the format of the yield log file. It is more intended as a debug tool to see every detail of the calculations. It isn't something you should need to sort through generally. Is there some reason you're needing to go through the log file?
by flight » Sat Dec 23, 2017 10:52 am
Yes, I use the log file to audit/check performance numbers, when something seems off.
Transfers, Exchange Offers, etc.
Can be problematic if you're not carefully on how they are recorded in FM.
flight
