account description options - advisor version
Postby investor » Mon Oct 27, 2008 11:09 am
Hi Mark - when I run an "investment transactions" report I select the option of "do not display" for account description as I don't need this to be included in the body of the report. But then the account name does not appear on the report heading. Is there a way around this? or, if not the options could be expanded?
Thank you.
Chris
investor
Postby Mark » Mon Oct 27, 2008 5:25 pm
Hi Chris,
Select "Options / Report Headers..." and then under "Sub-Title" choose "Insert Field..." and insert "SUBPORT_ACCT". There are a lot of other fields here you can also insert.
Postby investor » Tue Oct 28, 2008 11:18 am
Thank you.
investor
