Adding a Column to a Standard Report
Postby ACuriousInvestor » Sat Apr 07, 2018 11:13 am
I'd like to add the "Investment Goal" field as a new column in the existing Open Lot report. Can the standard reports be modified in this way, or do I need to build a custom report for this?
Thanks in advance for the help!
ACuriousInvestor
Postby data8504 » Sat Apr 07, 2018 11:19 pm
Hi ACuriousInvestor. Welcome to the forums!
There are some customizations that can be applied to the Open Lots report (from Options > Report Preferences > Open Lots), but unfortunately adding Investment Goal isn't a current option. Also, your idea of creating a custom report also won't really accomplish what you want because custom reports only list by symbol, investment, ..., but *not* by investment lot.
Would you mind taking a step back and explaining exactly what you're trying to accomplish at a high level? Maybe there's another way to display the data you're looking for.
A possible workaround: You can use a filter on the Open Lots report to show only lots of a specific Investment Goal. In this way, you could have a report for each of your goals.
Let me know if I can help further,
-Matt
data8504
