Reports recalculated twice with Apply button
Postby Djobydjoba » Thu Jul 26, 2018 11:41 am
Very minor feedback:
1) A report opened with, for example, the Correlation column displayed
2) We want to change the Benchmark. So Right click > Report Preferences > Benchmark tab
3) Change the Benchmark Investment.
4) Clic Apply > The report is re-calculated
5) Clic Close > The report is re-calculated again
So two-recalculations. Only one would be sufficent (either at the Apply stage OR at the close stage)
(Same when changing one of the others fields of the Benchmark tab)
Postby Djobydjoba » Thu Jul 26, 2018 11:59 am
And three same recalculations if:
1) A report is opened
2) Right clic > Settings
3) Preferences Button
4) Benchmark tab, change a field, Apply button -> first recalculation
5) Close button (Report Preferences window) -> second recalculation
6) Done button (Report Settings window) -> third recalculation
Postby Mark » Thu Jul 26, 2018 2:04 pm
Thanks. We'll get the Apply/Close issue fixed in the Report Preferences / Benchmark dialog. The Report Settings dialog always re-calculates a report when you press Done. It doesn't currently have the logic to know that if nothing was changed it doesn't need to re-calculate. This is a bit bigger change, so it is something we will hold off on for now.
