dividend info
Postby JeanneMarie » Wed Aug 29, 2018 2:23 pm
In a custom report, what are "distributed distributions /share (current)"? This number would result in a 22.5% yield. But it is definitely not a year's distributions (alas).
JeanneMarie
Postby Mark » Wed Aug 29, 2018 2:55 pm
Hi JeanneMarie,
From the documentation on the Custom report it says:
Code: Select all
Sum of all per share distributed distributions received by only the shares owned on the ending report date.(Dist dist-C /s (end) = Dist dist-C (end)/End shares)
It is not necessarily the distributions from just a single year. It is the total for however long you've owned the currently owned shares.
