custom columns in portfolio editor view
Postby Nick » Sun Sep 09, 2018 8:19 pm
Hi Mark
I have added a custom column to the view. How do i define/edit the column please?
Nick.
Nick
Postby Mark » Mon Sep 10, 2018 5:27 am
Hi Nick,
Do you mean a custom investment property? If so, you can edit these under the Options top level menu.
Postby Nick » Tue Sep 11, 2018 11:00 pm
Hi Mark I mean the custom columns in the Portfolio Editor view
View -> List Columns...-> List columns to display
How do I edit those?
Thank you.
Nick
Nick
Postby Mark » Wed Sep 12, 2018 6:28 am
Hi Nick,
To display any of the available fields just put a check mark next to that field. You can also reorder them so they display in the order you want. You can only choose from the list of available fields. You can't define or add new fields if that is what you're asking.
Postby Nick » Wed Sep 12, 2018 2:57 pm
I thought here was where I could do something like showing how big my position is as a %age of a 10 day moving average of volume
Is it possible to do that?
Nick.
Nick
Postby Mark » Thu Sep 13, 2018 6:46 am
Hi Nick,
You cannot define your own fields for the Portfolio Editor. In the Professional and Advisor versions you can define your own fields for the Custom Report. See the Define Fields... button in the dialog where you choose which fields to display in the Custom report.
Postby Nick » Thu Sep 13, 2018 5:20 pm
Thanks Mark
Nick
Postby Nick » Fri Sep 14, 2018 9:39 pm
Thanks Mark
Is it possible to have a field as described expressing a position as a percent of a moving average of volume (e,g, 10days) and display that in a graph please?
or would I need to set that up as a user defined field and then set up another field that would look at MAX of that field in a report? if I am looking at moving average excluding weekends is it
- Average(-10, 0, number, 0)
and what is daily trading volume please?
and what is the field for position in number of shares
Nick.
Nick
Postby Mark » Sun Sep 16, 2018 4:59 pm
Hi Nick,
You can't graph user-defined fields. These are only available in a Custom report. For help on using these, see the documentation here:
https://www.fundmanagersoftware.com/hel ... ields.html
and for help on the AVERAGE function, see:
https://www.fundmanagersoftware.com/hel ... ml#AVERAGE
and for help on using date arguments, see:
https://www.fundmanagersoftware.com/hel ... _arguments
An example, might be:
AVERAGE(ENDDAYS() - 10, ENDDAYS(), End_volume, 0)
End_volume is the volume on ending date, and End_shares is the number of shares owned.
Postby Nick » Sun Sep 16, 2018 6:22 pm
Thanks Mark
So - to get any historical context - one needs to run multiple custom reports and save the data out of FM?
Nick
Nick
Postby Mark » Mon Sep 17, 2018 8:32 am
Hi Nick,
Yes, you could do that, or you could create a single report with up to 6 date ranges.
Users browsing this forum: gmow and 5 guests
