Rebalance Report Allocation Target Percentages
Postby mdickson » Fri Dec 19, 2008 12:58 pm
Tryin to do a rebalancing report - my targeting is by asset type.
Unfortunately my target asset allocation has some asset types that have allocations that are not whole numbers - for example, emerging markets might be 6.75% of my total allocation.
However, the report seems to only allow entry for whole number percentages.
Am I doing something wrong - if not, perhaps an enhancement for a future revision?
mdickson
Postby Mark » Fri Dec 19, 2008 1:14 pm
Hi mdickson,
You aren't doing anything wrong, the percentages are limited to integer values. Thanks for the feedback, we can consider this for a future update.
Postby fiscalis » Wed Jan 28, 2009 7:05 pm
HI Mark,
I'm just adding my 2 cents worth. If you could update the rebalancing targets to allow for 2 decimals it would be fantastic. My overall models are all whole numbers, but when I start slicing and dicing I end up with decimal values too.
THANKS.
fiscalis
Postby Mark » Thu Jan 29, 2009 8:33 am
Hi fiscalis,
Thanks for the feedback. We probably should have done it that way in the first place...
