Custom and Memorized Report
Postby divinest » Sun Jan 20, 2019 10:25 am
Wanted to check if this expected behavior and if there is a way to choose in the preferences
1. If I create a custom report in the drop down and view the report (the report is fine with selected fields)
2. If i open a report from memorized reports (which happen to be build based on a custom report)
3. The Custom report created adhoc (step 1), always gets overwritten with the last custom memorized report that i opened.
In other words, opening a memorized report (using custom selections) always overwrites the custom report saved in the drop down. Is there a way to avoid this behavior or is this how its expected to work.
Again, thanks for your time in advance.
divinest
Postby Mark » Sun Jan 20, 2019 10:44 am
Hi divinest,
Yes, this is expected. When you create a report from the top level Reports menu, you are creating a new report. The default settings for a new Custom report are whatever your last created Custom report used, whether that was created new or from recalling a memorized report.
