Report Font.
Postby aviator » Sat Feb 02, 2019 8:27 am
When I run stock FM reports (i.e. unmodified other than date and account), the report font is tiny. This happens to all stock reports.
Interestingly, when I view a customized report, the font settings are as I expect (not tiny). What am I doing wrong?
Postby Mark » Sat Feb 02, 2019 9:57 am
Hi aviator,
When you create a new non-memorized report, your last set report font is used. If you want to change this use "Options / Report Font..." within a report window. Whatever you set here will be your default when you create a new non-memorized report.
When you recall a memorized report, the font is also recalled as part of that memorized report. Memorized reports remember their font settings, and don't use your new report default font.
