Portfolio Value List by Symbol (filter) exclude
Postby divinest » Fri Feb 15, 2019 6:15 pm
Hi Mark, You may have very well answered this before (i wasn't able to find in the forum search). I have the same stock across two portfolio i could do a list by symbol to get the %allocation in the performance report, however if i want to exclude an asset type (such as mutual funds) and want to see only stock holdings percentages across portfolios - how can i do that? As the filter icon is greyed out as soon as I select the list by symbol. Is there a workaround using a custom report with custom fields ? Thanks much
divinest
Postby Mark » Sat Feb 16, 2019 8:31 am
Hi divinest,
You have 2 ways you can do this:
1) List by "Investment Type".
2) List by "Investment" and then you can filter by "Investment Type". You can't filter when listing by "Symbol".
Postby divinest » Sat Feb 16, 2019 8:36 am
Thanks Mark, That works for investment type; however here is an example of what i am looking for
I have PG in two portfolio along with other stock, and ETF. If i want to see total portfolio percentage as only the Stocks (exclude investment type of ETF) but group all the same symbol together how would i do that.
divinest
Postby Mark » Sat Feb 16, 2019 9:54 am
Hi divinest,
That is a permutation you can't do. You can list by Investment, and filter out the ETF type, and you'll have 2 listings for PG in this example. You can't list by symbol and filter out the ETF type.
Postby divinest » Sat Feb 16, 2019 10:34 am
Thanks Mark. Was wondering if there a is a specific reason that prevents to view the grouping mentioned? Also do you see if this is something can be done with custom fields and reports? I am.using FM pro edition
divinest
Postby Mark » Sat Feb 16, 2019 10:43 am
Hi divinest,
There is no fundamental reason that permutation can't be supported, it just isn't a feature available today. I can't think of a way to do this with a user-defined field either. The best I can suggest is to list by investment. If you wanted, you could export the investment listed report to Excel and sum them by symbol in Excel.
Postby divinest » Sat Feb 16, 2019 10:48 am
Sounds good. Thank you. FM is a wonderful software enjoy using it.
divinest
