Yields showing up as NA
Postby gmonteferrante » Sun Mar 17, 2019 5:42 am
My yields on some investments are showing up as NA, despite the pricing data being available. Within the same portfolio, some investments are fine, but some show all yields as "NA", even with several years of data. This is a recent change, it had been working fine previously , although I did recently replace my computer (not sure if that is a possible problem?).
gmonteferrante
Postby Mark » Sun Mar 17, 2019 8:40 am
Hi gmonteferrante,
If you look at the log file, you can see the reason for the NA values. If you're in a report, use "Help / Logs / Report Calculation...". In a graph it is "Graph Calculation...".
Postby gmonteferrante » Sun Mar 17, 2019 10:02 am
Thanks, Mark, that helped to sort it out... had to change yield interp range...
gmonteferrante
