Is there a report(s) that breaks down the Portfolio Activity Summary, specifically Withdrawn Distributions? I'd like to know the detail behind the number presented for my selected time period.
Executive Summary.
Hi aviator,
Yes, use the "Investment Transactions" report, and in the Report Settings... dialog choose "Filter..." and then turn on the filter: Include Only Portfolio External Transactions (Contributions/Withdrawals) If you only want to see the component for Withdrawn Distributions, un-check the: Purchases / Transfer In Redemptions / Transfer Out Splits Notes transaction types. This will show you only distributions that were withdrawn from the portfolio. It is also a useful technique to see the details of Contributions and Withdrawals.
Got it, thanks, that worked.
A couple of questions, please: 1) Also on the report is Withdrawals (different from Withdrawn Distributions). What combination of filter settings do I need to reconcile that? 2) On my screen, this report is long but the bottom 2/3s is blank. Is there a way to incorporate stock (or even custom) reports into the blank bottom portion? I'd like to provide detail to the Portfolio Activity Summary box (for example, withdrawals and withdrawn distributions), and the bottom of the page seems like the logical place to put it. Thanks.
Hi aviator,
2) You can add indices, comments, and a graph. You can't add another report here though. From within the Report Settings... dialog, see "Options..." and "Select Indices...". There are also other options you can customize under "Options / Report Preferences... / Executive Summary".
Who is onlineUsers browsing this forum: No registered users and 4 guests |
